fredtsai
Jun 26, 2017Tutor
2.4g connection unstable while 5g works perfectly
Well, I tried to look for similar situation but unfortunately I wasn't able to find one, and thus I created this new discussion. I have the R6900 Nighthawk AC1900 setup at my living room. In fact...
- Jun 28, 2017
I kind of worked it out what is going on.
I found that the only thing I need to do is to disable the "20/40 MHz Coexistence" and everything just came back to normal.
I don't know how to put up a picture here, but anyway I tried to use my Dropbox link as below to show you.
I think I did the 2.4Ghz channels right by reset the channels with each router/AP, and I'm quite sure that the signal/channel should not have much overlap or interference in between, but after a few hours of trying I still had no luck.
When I tried to go through all the settings after reset the router to factory default, I found that originally when it is default to be 20/40 MHz. Some articles in other post showing that the system will most likely to use 40 MHz as preferred setting. Then I went back to see all the other router/AP's setting, found that all of my other routers/APs set the frequency width to be 40MHz. I guess that should also means better performance at some level, but unfortunately in my case the wider frequency width from the other routers might just squeeze out the available channels for my R6900.
Anyhow, after disabled the 20/40 MHz Coexistence, the problem seemed to be gone for now. I will stick around and do some more tests and if I got any I will post it here then.
I guess my issue is not very common in most cases, but hopefully my experience can provide some help to those who needed!!!
fredtsai
Jun 26, 2017Tutor
Thanks for your suggestion FURRYe38, but the channels in 2.4Ghz I tried all 1, 6, and 11 but no good luck.
I live inside my factory, and I setup the network (both wireless and wired) on my own. I run a canned food factory in Thailand, and pretty much no other neighbor close by around my location. I have wifi access almost everywhere inside my factory, and I am quite sure that there are not so many wifi interefere here as all the wifi signal that I can get is what I configured, and I already use different channels while I install those AP/routers.
I use cisco load balancer RV320 to combine/load blanace 2 ISPs for main source of internet. I know one of the ISP modem is made by Hwawei but the other one is really unknown. I will double check on that and post it here again.
Back to the setting, I did tried to remove any security and leave it without any password. I was able to connect, but with a very slow speed even standing right beside the router. When I turn the security password on (WPA2 and AES only), the 2.4Ghz network became unstable again. I did tried to change to other password but the situation seems the same. Meanwhile, no matter what I change in configuration, 5Ghz network still flying real fast and stable.
Well, I am actually at work right now, I will try to do some more test and will post the result here once I get some.
fredtsai
Jun 28, 2017Tutor
