KILLASAURUSFLEX
Apr 16, 2024Follower
2.4Ghz AP not working
I have a R7900P — Nighthawk X6S AC3000 Tri Band WiFi Router. After a recent firmware update the 2.4ghz band ap will not activate. I have down reverted to older firmware, done a factory reset, power c...
Apr 17, 2024Guru - Experienced User
Last resort maybe a 30-30-30 reset.
IF this fails, then maybe time to find something new. This model is EoL.
One could just disable the wifi radios on this router and then connect up a different wifi system in AP mode while leaving the router portion of the R7900P going if it's still working for you.
Good Luck.
