Hipjimmer's avatar
Jun 15, 2021
2.4gHZ issue with unable to connect/dropped connections
I have a AC2400/R7350 Nighthawk router that started having issues with the 2.4 GHz channel.  I have just purchased this and it replaced an N900 that never/ever dropped bands or connections.
I have a feeling it may be linked to the new firmware upgrade but not sure. The 2.4 GHz channel works fine after a reboot for a few hours, after which it will not allow me to connect to the channel.  After some time, the provisioned/connected devices lose their 2.4GHz connection. The 5 GHz channels work fine. This runs a lot of home automation and will go back in the box if this can't get resolved.
FW: V1.2.0.76_1.0.1
Guest Network: Enabled with Different SSID
Did anyone else have similar issues and if so any suggested solutions that will work?
  • I set the 2.4gHZ band to Channel 11 and after a week or so, this appears to be resolved.
  • plemans's avatar
    Did you try changing wifi channels?
    Or even just a factory reset and reinstall? sometimes the firmware auto-update installs and can cause issues. Its why some people prefer to disable auto-update.
    • Hipjimmer's avatar
      Hipjimmer
      Tutor
