dellpa
Jul 15, 2018Aspirant
2.4ghz network disabled for one device only after attack warning
Yesterday I received a red warning message that there was an attack on my wifi network and the 2.4ghz was disabled. Since then, I have checked to make sure that my firmware is up to date (it is), I'...
- Jul 16, 2018
Hi,
Try resetting your router by pressing the Reset button for 5 seconds.
Don't do any longer then 5 seconds or it might reset your router to Factory settings.
Nigelh92
Jul 16, 2018Tutor
Hi,
- dellpaJul 16, 2018Aspirant
Nigelh92 wrote:
Hi,
I must have held it just over 5 seconds because it reset to factory settings. I set everything up again and the problem is solved, so I don't mind. :-) Thank you very much for the suggestion. I had unplugged it but did not even notice the reset button until I went back to look for it.
