dellpa's avatar
dellpa
2.4ghz network disabled for one device only after attack warning
Yesterday I received a red warning message that there was an attack on my wifi network and the 2.4ghz was disabled.  Since then, I have checked to make sure that my firmware is up to date (it is), I'...
  • Nigelh92's avatar
    Jul 16, 2018
    Hi,
    Try resetting your router by pressing the Reset button for 5 seconds.
    Don't do any longer then 5 seconds or it might reset your router to Factory settings.
