chris49480
Jun 21, 2021Initiate
2.4GHz wifi security settings won't save (AC1750 / C6300v2 Modem Router)
I have set up my new Netgear AC1750 Wifi Cable Modem Router (model C6300v2) and it works great except for one problem: the security settings for the 2.4GHz wifi frequency won't save. The password...
- Jun 22, 2021have you tried a simple factory reset and reinstall?
chris49480
Jun 22, 2021Initiate
Thanks, I was able to fix it with a factory reset. Problem solved!
Jun 22, 2021Guru - Experienced User
Glad it helped!
