K8rain
Jul 29, 2021Follower
2.5 and 5G lights not on (R7000P)
Only lights on my router are the on and the internet light…. Where did the other ones go??? I obviously have no internet. HELP!
michaelkenward
Jul 30, 2021Guru - Experienced User
Maybe someone, or something (cats have done this), turned off the wifi with the wifi on/off switch on the top.
You can still plug things into the Ethernet ports on the back.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
