FILIPINOY79's avatar
Jun 10, 2021
2.5G Port
So, my internet provider sends me a email saying we bumped you to 1200mbps while I was at 1000mbps.   I noticed when paying my bill it says my modem isn't supported.  I'm like great what do I have to buy.  So here's my question.
If you get their modem it does have a 2.5g port, and 3x 1g port.  So if i really wanted 1200mbps to all devices, would they need to be on wifi?
I didnt like their router cause i had a hard drive connected to my original router (seperate from the cable modem).
  • Which router model are you currently using?
    NETGEAR has only a few routers with a single 2.5 Gbps port but the rest is all 1 Gbps. To benefit wired, you need to have all ports be 2.5 Gbps. On wireless, if your client device is fast enough, you can theoretically reach 2.5 Gbps (depending on router also). I say theoretically because in practice you'll never hit exactly 2.5 Gbps
    You also need a modem with a 2.5 Gbps port. I'm not versed with NG modems so can't say if they already offer such
    • FILIPINOY79's avatar
      FILIPINOY79
      Tutor
      I figure that, you would need a modem and router that has a 2.5.  Then if your devices even get 1200mbps (which i'm "supposed" to get from comcast).
      When i connnected my computer to the port i wasn't seeing a stedy 1200.  Sometimes it was as much as a 1gpbs.  So i just said screw it, i put back my original setup lol.
        FILIPINOY79
        Tutor
        So basically if you get a modem and router with 2.5g port.  The only thing you can do is a single device that gets the 2.5 plug it into the router.  Or use the 2.5 from the modem to the 2.5 in the router and see if you get speeds on wifi devices.
        Are there switches wil multiple 2.5 ports?
