mchobbles2
Aug 27, 2021Tutor
2 Internet Speeds Offered
I have a netgear AC1750 Smart Router My wi-fi shows the 2 interent speeds my service provider offers (2G and 5G) however,when I change the password on the router it only seems to affect the 2G pass...
- Aug 27, 2021
In the gui, you can change them both. here's the instructions and a video how.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
Aug 27, 2021Guru - Experienced User
- mchobbles2Aug 27, 2021Tutor
try that, I've attempted other ways and been unsuccesfful
GOT IT!!!
Had to use incognito tab for some reason but it worked!
- plemansAug 29, 2021Guru - Experienced User
glad to hear you got it working, even if you had to end-run around it!
