techristian
Aug 18, 2021Initiate
200 mbps directly from NightHawk GS3000 and only 90 mbps thru NETGEAR GS308 SWITCH
So since I just bought this new NETGEAR GS3000 NightHawk , I figured that I would get a NETGEAR SWITCH to go with it. I bought the GS308 but it isn't passing through the same speed as it is receiv...
- Aug 18, 2021
Try swapping out cables. A sketchy cat 5e cable can sometimes cause the connection to be 10/100mbps and not gigabit.
Either make sure its a quality cat 5e or cat 6 cable.
techristian
I just crimped a new "cat 6" cable. It is only 2-3 feet long. Yes it works at full speed. I was a little nervous. Amazon said it was "cat6" but there were no markings on the cable.
Next I will need to upgrade all of my speed critical cables here.
Thanks
Dan
antinode
Aug 18, 2021Guru
I'd replace defective cables, if you can find any. The usual "cable"
problem is a defective connector attachement, not an actual cable
problem.
