SNOW-DM
Dec 10, 2021Guide
2021 R7000 goes offline every couple of months
It's not even a year old yet. I've had the problem twice since October - suddenly computer says there's no internet - wifi router only has orange light on far left. Turning it off and on doesn't ...
microchip8
Dec 10, 2021Master
Newest firmware version doesn't mean each time that it's the best. You can downgrade to an older version and see if it works for you. Then wait for future firmware that may fix your issue. Luckily, NETGEAR still supports the R7000
