Auroradawn
Jun 05, 2019Aspirant
28743565
Why is it that when I select my 5G it says it is out of range when my router is right underneath my device
- Jun 06, 2019
The control you shown this has not fixed anything - as it does not change anything on the router configuration.
We're always keen to learn however.
michaelkenward
Jun 06, 2019Guru - Experienced User
Help us out here with a bit more information.
What Netgear hardware is this?
What are you using to connect to the 5GHz wifi?
Apologies for the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
- AuroradawnJun 06, 2019AspirantThe model number is 28743565. Took a photo of the back since I have no idea what to select in your list. It is a Netgear81 and I attached a photo of the back of the router. It says that the WiFi is out of range when it is located right underneath my android box
- michaelkenwardJun 06, 2019Guru - Experienced User
Netgear81 Netgear81
Auroradawn wrote:
The model number is 28743565.That is not the model number. Your picture cuts off the bit that shows the model number.
Netgear81 is the SSID, the wifi source that you should connect to, using the password in the slot underneath it.
Is that what you are using when you get the "WiFi is out of range" message?
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
- AuroradawnJun 06, 2019AspirantCould not find the 5G only the 2g message was out of range when the modem is right below the android device
The CM400 in tour footer is a cable modem. It does not do wifi.
I repeat, what is the model number of your router?
It should begin with an R and look something like RXXXX.
- schumakuJun 06, 2019Guru - Experienced User
Auroradawn wrote:
It says that the WiFi is out of range when it is located right underneath my android boxThis reads like a bad idea, for thermal reasons, for interference reasons, ... you might want to consider an Ethernet connection instead.
Auroradawn wrote:
Why is it that when I select my 5G it says it is out of range...Unclear and vague. Does this Android box list the 5G network name on air, or are you trying to connect it to a stored connection profile, ...? Depending on the age and source of this Android box, it might be unable to work on the channels currently operational on your router - for example if one or the other was designed and designated to work under a different regulatory domain.
- AuroradawnJun 06, 2019AspirantEven my tv could not find it and it is a Bravia Sony 4K TV. I can connect my iPhone and laptop to the 5G but not my firestick or TV which is above the router
