Auroradawn
Jun 05, 2019Aspirant
28743565
Why is it that when I select my 5G it says it is out of range when my router is right underneath my device
- Jun 06, 2019
The control you shown this has not fixed anything - as it does not change anything on the router configuration.
We're always keen to learn however.
Auroradawn
Jun 06, 2019Aspirant
Model number is R6700v2
schumaku
Jun 06, 2019Guru - Experienced User
And the Android box is ...?
Can you see and connect the router 5G network from other devices, e.g. a mobile phone?
What do you see on this Android box? A photo might help to understand your question a little bit better.
