Tokyos
Feb 08, 2022Aspirant
2mb max speed download
Hey there, I ain't use to using something like this. Infact I like to use wireless but here we are with a pc what is wired. I use the ex2700 as a wifi range extender and hook the ethernet to my pc si...
Feb 08, 2022Guru - Experienced User
Somehow I doubt you used both 2.4ghz AND 5ghz as the EX2700 is a 2.4ghz single band device.
it can't pickup or use 5ghz at all.
Have you tried a different device to see if its a device specific issue?
