bakarnoma
Aug 16, 2022Follower
2nd Gen Echo Dot + Older Fire Stick will not connect to R7000
Hello, I've got a 2nd gen Echo Dot that would connect to any other network I've tried, except at my cottage where I have an R7000. I also have an older Fire Stick that will do the same, but a newe...
Aug 17, 2022Guru - Experienced User
What modem/gateway is the router connected to?
What firmware is on the router?
Any special characters/spaces in the ssid/password you're using? (if so, remove them)
