PAR7960
Jul 24, 2022Aspirant
2nd Router for iOT and Current Home Network
I want to add a new less expensive router next to my current Nighthawk Model R7960P for 2.4 GHz access points for all my iOTs and possibly additional Ethernet IP connections. The 2.4s work fine with ...
Jul 24, 2022Guru - Experienced User
They would be on a different subnet and behind two firewalls. This may or may not work well being in a double NAT condition.
You could set up the 2nd router for AP mode which would be on the same sub net as the primary router, still set up a 2.4Ghz SSID name for these IoT devices and they would connect to the AP mode router and you would have seamless access across the network.
- PAR7960Jul 24, 2022Aspirant
Thanks for the quick reply.
Will AP mode allow me to use the additional ports in the 2nd router for Ethernet connections, too? I will have to do some checking.
