PAR7960
Jul 24, 2022Aspirant
2nd Router for iOT and Current Home Network
I want to add a new less expensive router next to my current Nighthawk Model R7960P for 2.4 GHz access points for all my iOTs and possibly additional Ethernet IP connections. The 2.4s work fine with ...
PAR7960
Thanks for the quick reply.
Will AP mode allow me to use the additional ports in the 2nd router for Ethernet connections, too? I will have to do some checking.
Jul 24, 2022Guru - Experienced User
Yes.
- PAR7960Jul 24, 2022Aspirant
OK. I am set, as long as I still have IP addresses available and the Ethernet is in the same number scheme I am set. Going to Costco tomorrow for an AX2200, which I assume will work fine.
- FURRYe38Jul 24, 2022Guru - Experienced User
If you plan on having two wifi sources, just make sure the channels on each unit is using far apart channels. #1 using channel 1 and # 2 using channel 11. I would even turn down the power out out of the 2ndary AP to maybe 50% as well to ensure there isn't any interferences with the Primary wifi router. Otherwise, should all work well.
Thanks. Had already noted channels separation in someone else's post before I asked my question. And will evaluate whether the power needs to be dampened which I assume is in the manual.
