bull117
Jul 29, 2019Aspirant
2nd time crashing R7000 on firmware
Ok...now pissed. After first firmware update debacle...believed I fried the hardware where I only got wireless lights with flashing on light. So I bought a new R7000 a few months ago. Now I tried to u...
- Jul 31, 2019
> o I then opened the TFTP client that I downloaded: [...]
You should have been able to use the TFTP client which comes with
macOS:
https://community.netgear.com/t5/x/x/m-p/1622096#M102004
And, as it says at https://kb.netgear.com/000059633 :
[...] Make sure to extract the file from the zip folder. The
firmware file format is either a .img or .chk file.If you're on a Mac, and using Safari for the download, then I'd
expect Safari to extract the zip archive contents automatically. (At
least that seems to happen here, whether or not I want it to.) If you
use another browser, then double-clicking on the ".zip" file should do
that job.And, for an R7000, the firmware image file type should be ".chk".
antinode
Jul 29, 2019Guru
> [...] flashing on light [...]
Did you try using the TFTP recovery scheme? See, for example:
> [...] it crashed again!!! Tried even the reset button.
Not a very detailed description of what you did, or what happened
when you did it, or what the router does now.
> [...] This should not be this hard!!!
I agree, but there is a recovery mechanism.
bull117
Router does nothing but the white flashing on light (as mentioned in the first post). Details...the computer stated it could not complete the update. The router indicated a flashing white light and the computer direct connect. I clicked out of the genie. Powered off the modem and router...no luck. powered off just the router...no luck. Reset the router...no luck. Now folks want to use this TFTP program...a bandaid that NetGear should fix.
- antinodeJul 29, 2019Guru
> I have a Mac. [...]
So? There's a TFTP client program in macOS, too.
> [...] The TFTP process is great for someone versed in computer
> geekdom...I am not. [...]I wouldn't call it "great" for anyone, but using it should be
possible for anyone who can follow instructions, and has (access to) a
computer with an Ethernet interface.> [...] This issue should not even be [...]
Ok. Now, do you want to throw a tantrum, or repair your disabled
router? Either way works for me, but my time is too valuable to waste
on a tantrum.- bull117Jul 30, 2019Aspirant
Well...both really...a tantrum and a rant! In today's word, firmware updates should be seamless.
So...here is the status after spending hours on the phone. I used the TFTP and uploaded the zip file for the recent update to the router. It indicated successful after about an hour. Let it sit for 4 minutes per the instructions...and nothing. Still flashing power light. Called them back...they said try the reset button again for 1 min. Nada. Still flashing power lit. They want me to return it. Thus, I tried the older R7000 that I had with the same symptoms. Uploaded older firmware updates and nada...still a white flashing power light. Tantrum...you bet.
- antinodeJul 30, 2019Guru
> [...] I used the TFTP and uploaded the zip file for the recent update
> to the router. [...]What, exactly, does "I used the TFTP" mean to you ? Which file,
exactly, did you try to send to the router? (Hint: A ".zip" archive
would be the wrong answer.) How, exactly, did you do whatever you did?> [...] Uploaded older firmware updates [...]
when you did it. The TFTP recovery scheme is a multi-step procedure
which offers multiple opportunities for user input, hence user error.
Saying that you "used" or "tried" TFTP, with no details, is not a useful
problem description.
