bull117
Jul 29, 2019Aspirant
2nd time crashing R7000 on firmware
Ok...now pissed. After first firmware update debacle...believed I fried the hardware where I only got wireless lights with flashing on light. So I bought a new R7000 a few months ago. Now I tried to u...
- Jul 31, 2019
> o I then opened the TFTP client that I downloaded: [...]
You should have been able to use the TFTP client which comes with
macOS:
https://community.netgear.com/t5/x/x/m-p/1622096#M102004
And, as it says at https://kb.netgear.com/000059633 :
[...] Make sure to extract the file from the zip folder. The
firmware file format is either a .img or .chk file.If you're on a Mac, and using Safari for the download, then I'd
expect Safari to extract the zip archive contents automatically. (At
least that seems to happen here, whether or not I want it to.) If you
use another browser, then double-clicking on the ".zip" file should do
that job.And, for an R7000, the firmware image file type should be ".chk".
IrvSp
Jul 31, 2019Master
You missed step 6:
Download and save the router’s firmware onto the desktop of your computer. Make sure to extract the file from the zip folder. The firmware file format is either a .img or .chk file.
It is inside the ZIP file which needs to be extracted.
Error 2, don't use the .88 f/w, buggy as can be. Most people agree V1.0.9.42 is the last good working firmware.
antinode
Jul 31, 2019Guru
macOS:
that job.
- bull117Jul 31, 2019Aspirant
Well...that worked, The .zip file was the wrong file to upload. I now have two R7000...just in case it crashes again on a firmware update :) (it really shouldn't happen and makes people nervous doing the update).
Regardless...my thank you for your patience and perseverence. Best
- antinodeJul 31, 2019Guru
> Well...that worked, [...]
Thanks for the report. (What could go wrong?)
