dkopp
Apr 11, 2018Aspirant
2x R7000 extend WIFI network searching for right configuration
Hi ; I have bought a 2nd R7000 AC1900 WIFI router.. My setup is as follows. - Supplier router where I have disabled WIFI - Then network cable (LAN) connected from the base router to the 1st R700...
- Apr 12, 2018
dkopp wrote:
What I mean is if I have actually have to change the modes on the routers from AP to maybe bridge mode?No, AP mode for a configuration with a wired backbone.
dkopp wrote:
My issue usually is my phone (for example) sticks too long on the weak downstairs channel then to switch to upstairs. I was hoping to get one signal convering both floors.Same name (SSID) on all wireless interfaces - or (if this should not be possible) at least the same name (SSID) for the 2.4 Ghz on both routers and both 5 GHz interfaces on both routers?
schumaku
Apr 12, 2018Guru - Experienced User
Perfect correct set-up.
dkopp wrote:Question how do I configure them both to support extending of my WIFI signal with the same SSID without having to manually switch between downstairs and upstairs. How to do this?
Your installation does not extend the WiFi signal - much more you have two wiress access points with cabled connections to the network. Much better!
Configure the same network name (SSID) and password (network key) on all radios. Not sure it is possible to have the same name on the 2.4 and 5 GHz radios, due to some **** design ideas, the Web configuration might prohibit. However, you mentioned only usung the 5 GHz radio, so this limitation does not apply. Your wirless systems can decide on their own to use the better access point.
- dkoppApr 12, 2018AspirantHi thnx for your reply.
What I mean is if I have actually have to change the modes on the routers from AP to maybe bridge mode? My issue usually is my phone (for example) sticks too long on the weak downstairs channel then to switch to upstairs. I was hoping to get one signal convering both floors.- schumakuApr 12, 2018Guru - Experienced User
