dkopp's avatar
dkopp
2x R7000 extend WIFI network searching for right configuration
Hi ; I have bought a 2nd R7000 AC1900 WIFI router.. My setup is as follows.   - Supplier router where I have disabled WIFI - Then network cable (LAN) connected from the base router to the 1st R700...
  • schumaku's avatar
    schumaku
    Apr 12, 2018
    dkopp wrote:
    What I mean is if I have actually have to change the modes on the routers from AP to maybe bridge mode?
    No, AP mode for a configuration with a wired backbone.
    dkopp wrote:
    My issue usually is my phone (for example) sticks too long on the weak downstairs channel then to switch to upstairs. I was hoping to get one signal convering both floors.
    Same name (SSID) on all wireless interfaces - or (if this should not be possible) at least the same name (SSID) for the 2.4 Ghz on both routers and both 5 GHz interfaces on both routers?
