Small-ISP
Oct 06, 2022Aspirant
/31 Subnets
I work for a ISP and just got off the phone with gentleman that that said he had a Nighthawk. When he tried to set a /31 it gave him an invalid subnet error. Searching here I see older posts saying t...
- Oct 08, 2022
Well would need to know what exact NG model. Users seem to use "Nighthawk" as a over all model for everything. NIghthawk covers many different models. There is is NON NIghthawk routers as well.
Is this for a Mobile Router?
The /31 maybe something supported on a ISP side of things however when it some to a LAN side and home users intended target of having multiple devices, this would not be something that NG would use nor be supported on the LAN side. LAN side for consumer home users generally have way more than two device, would not have a need for this kind of configuration and thus this configuration would not work. I just checked my XR1000 on the lan side for this and it's not taking the sub net mask for /31. So I presume NG doesn't support his kind of configuration on there routers.
/31 would be seen on point to point connections I would presume and thus mostly seen in maybe business or enterprise class environments. I would hope that more appropriate equipment would be used here and not a consumer grade low budget router if that kind of configuration is needed.
Small-ISP
Oct 07, 2022Aspirant
Not sure what model. He only referred to is as a Nighthawk. I assumed they all used the base OS. Also my interest is about the entire line. Customers with Nighthawks generally don't call in with speed test issues. If I need to tell customers to avoid 1 or 2 specific modules that's fine, but I'd rather not tell them to avoid them altogether if they are using /31.
/31 supports 2 host using 2 addresses. /30 supports 2 hosts using 4 addresses. Why burn the extra 2 addresses when thay are over $40 a pop currently?
We don't do homes in the part of the network I'm in. Recently we started offering speeds lower than 1G. It's attracting business that do not have IT departments so we are seeing more Soho gear and fewer IPs needed. /29 is what most customers get.
Oct 08, 2022Guru - Experienced User
