BaptisteX1
Dec 16, 2021Aspirant
400 demande incorrecte
Bonjour, Je suis sur un routeur Nighthawk X6 R8000 AC3200, sur la version R8000-V1.0.4.76_10.1.82. Je rencontre un problème quand je souhaite fixer un IP. Dans la partie avancé>configuration>param...
- Dec 21, 2021
Hello,
I finally found the solution to my problem. :smileywink:
Do not underscore the name of the equipment. It must have been since the update, because some of my equipment that was added before does have an underscore in its name.
BaptisteX1
Hello,
I am on a Nighthawk X6 R8000 AC3200 router, on version R8000-V1.0.4.76_10.1.82.
I have a problem when I want to set an IP.
In the advanced part> configuration> LAN settings> add.
I get the following message: 400 Bad Request - This server does not support the operation requested by your client.
I do not understand why I am receiving this message, when I have already set IPs before this day.
For information, I tried the manipulation with two different browsers (Edge and Mozilla).
Hope to have a solution to this problem.
Thank you in advance for your answers.
Dec 17, 2021Guru - Experienced User
Does powering OFF the router for 1 minute then back ON help any?
You might need to factory reset the router and setup from scratch...
