BaptisteX1
Dec 16, 2021Aspirant
400 demande incorrecte
Bonjour, Je suis sur un routeur Nighthawk X6 R8000 AC3200, sur la version R8000-V1.0.4.76_10.1.82. Je rencontre un problème quand je souhaite fixer un IP. Dans la partie avancé>configuration>param...
- Dec 21, 2021
Hello,
I finally found the solution to my problem. :smileywink:
Do not underscore the name of the equipment. It must have been since the update, because some of my equipment that was added before does have an underscore in its name.
BaptisteX1
Dec 18, 2021Aspirant
I have performed the requested manipulation and it does not change my problem.
FURRYe38 wrote:Does powering OFF the router for 1 minute then back ON help any?
You might need to factory reset the router and setup from scratch...
BaptisteX1
Dec 21, 2021Aspirant
Hello,
