jimmyfor20
May 03, 2017Aspirant
5-3-17 R7000 firmware killed my lanport download speed
Updated my firmware to latest version from netgear. Now my lan ports won't go over 10.5Mbps. WiFi seems unaffected. I'm still getting 110 to 117Mbps. Netgear... You f'ed up. 90% of my bandwidth is go...
- May 05, 2017
ok, I think I've resolved my issue I had xfinity tech come out to check their circuit. The tech sent a signal down to my Motorola SB6141 Modem to reset it. This step had been done over the phone by Xfinity customer service twice a few days ago with NO effect. Then I disconnected all wiring except for power on the R7000. I did a "factory reset" with a paperclip on the back of the R7000. I then connected ethernet devices one by one. My speed came back except on one PC. It was still stuck on 12Mbps up and 12Mbps down. The PC has a Killer E2200 NIC on the motherboard. I downloaded diagnostics from Rivet networks. After running the diags on the PC, it fixed the NIC. My speed is now restored to the pre-update levels of 125Mbps down and 12Mbps up on BOTH wired and wireless ports. I turned on QoS and it killed my bandwidth, so I turned it back off.
My advise to anyone with this issue would be to disconnect all network devices BEFORE updating the router. It seems like when a update of the router is done, the update will cause your other devices to become corrupted. I'm on an older firmware now.... the one that ends with 99.ck or something like that.... That's where I'm staying for a while.....
May 03, 2017Guru - Experienced User
Was a factory reset performed before and after applying the FW update?
Was all QoS and Traffic Monitoring features disable while speed testing?
Are you testing speeds with a LAN wired PC with all security software disabled on the PC while testing?
Trying different browsers and different speed testing sites and servers?
- AhnFireMay 04, 2017Guide
Same thing happened to me. It took me a downgrade + upgrade + multiple factory resets... i think it's back to normal. I also turned off QoS (or made sure it was turned off). I stil have some problems... my router into a switch... one of my devices on the switch suddenly dropped to 10mbps as well. Wifi is normal. I am not happy with this upgrade either. What is the deal with the UBS2.0 light?
- jimmyfor20May 04, 2017Aspirant
What is a "factory reset"? How is this done? Is this done in the router menu, or by paperclip on the unit itself? I went into "backup settings" and reset the router there. Do all lanports need to be disconnected while doing the firmware update?
jimmyfor20 wrote:What is a "factory reset"? How is this done? Is this done in the router menu, or by paperclip on the unit itself? I went into "backup settings" and reset the router there. Do all lanports need to be disconnected while doing the firmware update?
I initially did it like you did in the menu there. However, something happened and then it refused my connections to 192.168.1.1, so I had to do it with the paperclip + 6 seconds way.
- FURRYe38May 04, 2017Guru - Experienced User
Factory reset can be done from the UI or from the back reset button. Both do the same thing. Review the user manual for location and information on factory resets.
Ok, so I did my factory resets through the U.I. They don't fix my issue. I have a very simple setup. No Qos, No port forwarding, No remote admin. Wondering if I should disconnect all ports while doing the flash\update? This step wasn't recommended by Netgear. I've flashed BIOS on many Dell computers. It has always worked first time. Netgear, you need to step your game up. Your customer service is HORRIBLE. You put out bad firmware, they charge people $$$ to fix. If I ever get this issue fixed, trust me, I'll NEVER buy Netgear products again. I work in I.T., and lots of people ask me for recommendations for home network equipment. I won't be recommending ANYTHING from Netgear, due to their lousy support.
