Dcbank2001
Aug 25, 2020Aspirant
50% slower internet speed (wired)
Hi, I'm have Netgear Nighthalk x6s Ac4000 tribanf Wifi Router,Newest firmware possible V1.4.1.50_1.3.10. I have the nighthalk in router mode, also have an IP passthough on the router as well, but so...
- Aug 27, 2020
You can play more with passthrough mode or even putting the netgear in the att's router dmz.
But if the netgear is getting 100% speed in access point, its the issue of running 2 routers in router mode on the network.
Aug 26, 2020Guru - Experienced User
What gateway is it connected to?
Have you tried leaving the gateway in regular router mode and putting the netgear in access point mode?
- Dcbank2001Aug 26, 2020Aspirant
It's a new Att fiber only gateway bgw320, may have been released 2 weeks ago, same issue with the other equimpent bgw210 as well. I have never tried AP mode. However I've tried leaving the gateway in router mode and when i connect directly to the gateway i get 100% of the speed.
plemans wrote:What gateway is it connected to?
- plemansAug 27, 2020Guru - Experienced User
Att gateway's are notorious for being a PITA to get working properly in passthrough modem only mode.
If it works fine in router mode, try the netgear in access point mode.
- Dcbank2001Aug 27, 2020Aspirant
It worked, I getting 100% speed now but i lost mostly all the features i brought the router for. Is their no other way to get it in router mode and keep 100% speed?
Thanks in advance.
plemans wrote:Att gateway's are notorious for being a PITA to get working properly in passthrough modem only mode.
