Dcbank2001
Aug 25, 2020Aspirant
50% slower internet speed (wired)
Hi, I'm have Netgear Nighthalk x6s Ac4000 tribanf Wifi Router,Newest firmware possible V1.4.1.50_1.3.10. I have the nighthalk in router mode, also have an IP passthough on the router as well, but so...
- Aug 27, 2020
You can play more with passthrough mode or even putting the netgear in the att's router dmz.
But if the netgear is getting 100% speed in access point, its the issue of running 2 routers in router mode on the network.
Aug 26, 2020Guru - Experienced User
What gateway is it connected to?
Have you tried leaving the gateway in regular router mode and putting the netgear in access point mode?
Dcbank2001
Aug 26, 2020Aspirant
It's a new Att fiber only gateway bgw320, may have been released 2 weeks ago, same issue with the other equimpent bgw210 as well. I have never tried AP mode. However I've tried leaving the gateway in router mode and when i connect directly to the gateway i get 100% of the speed.
plemans wrote:What gateway is it connected to?
- plemansAug 27, 2020Guru - Experienced User
Att gateway's are notorious for being a PITA to get working properly in passthrough modem only mode.
If it works fine in router mode, try the netgear in access point mode.
- Dcbank2001Aug 27, 2020Aspirant
It worked, I getting 100% speed now but i lost mostly all the features i brought the router for. Is their no other way to get it in router mode and keep 100% speed?
Thanks in advance.
plemans wrote:Att gateway's are notorious for being a PITA to get working properly in passthrough modem only mode.
