DeeMe10
Jan 02, 2021Aspirant
5G Authentication error occurred.
Hi. I just purchased Nighthawk AC1900 WiFi Cable Modem Router model C7000v2. It was working fine until 3 days ago. 5G network stop connecting. I got 2 msgs. 1st "Failed to obtain IP address" & 2nd "Au...
DeeMe10
Jan 03, 2021Aspirant
Yep. Didn't do anything!!!
Jan 03, 2021Guru - Experienced User
is it only wireless devices with that issue?
Do wired devices work fine?
- DeeMe10Jan 03, 2021AspirantBoth don't work.
- plemansJan 03, 2021Guru - Experienced User
both 2.4ghz and 5ghz? And wired?
You're not being very detailed.
What happens when you factory reset?
Are you able to access the gui through the browser?
- DeeMe10Jan 03, 2021AspirantBoth 2.4ghz and 5ghz don't work including wired connection. 2.4 works just fine on both ends. (WiFi & wired)
