DeeMe10
Jan 02, 2021Aspirant
5G Authentication error occurred.
Hi. I just purchased Nighthawk AC1900 WiFi Cable Modem Router model C7000v2. It was working fine until 3 days ago. 5G network stop connecting. I got 2 msgs. 1st "Failed to obtain IP address" & 2nd "Au...
Jan 03, 2021Guru - Experienced User
both 2.4ghz and 5ghz? And wired?
You're not being very detailed.
What happens when you factory reset?
Are you able to access the gui through the browser?
DeeMe10
Jan 03, 2021Aspirant
After factory reset? Same thing. Do not work. Are you talking about Netgear genie? If yes than yes, l can use it.
