roger_h
Apr 29, 2021Aspirant
5g DFS channels in US r7000 r7000p ex7000 and in general. All firmware release notes lacking data.
R7000 R7000P EX7000 all firmware realease notes. I have R7000 R7000P and Ex7000's used as AP - Extender pairs. All at various firmware levels. One of the EX7000's is at V1.0.1.94_1.0.172 and I ...
- Jun 11, 2021
I might as well close this out. After numerous searches and reading about this and the response in general from all software and firmware providers, seen in searches and personal experience: My conclusion is that the "as is" "as available" clause to protect the providers is being abused to excuse sloppy programming and sloppy testing and non existant support.
I believe this allows hiring the cheapest programmers and testers and support staff! There is no incentive to actually test changes since no responsibility is required. LET THE BUYER BEWARE. SPEND UPFRONT TIME TO TEST AND EVALUATE ANYTHING YOU BUY. THEN TAKE BACK AS SOON AS YOU FIND IT IS CRAP. DO NOT TRUST ANYONE!
The EX7000 pair I am using are not perfect, but are acceptable for the near future as a replacement for the R7000p/EX7000. My only complaint is that the power level setting does not seem to make a difference. Although at 25% 5g dropped out. So I abandoned further testing. Enough is enough. I can get obsessed with trying. As some say "its does no good to kick a dead horse".
roger_h
May 31, 2021Aspirant
Tried the following:
Completely avoiding the Smart Wizard | Answer | NETGEAR Support
Worked as it should have, like the old way to setup. Routerlogin.net is so buggy and crappy.
After setting up the only glitch was I had to reset modem,and routers, APs to get login to my router due to 192.168.1.1 conflict.
I always prefered to setup my network devices at my couch.
The wifi speed seems to be equal on the R7000P/Ex7000 vs EX7000/EX7000. So now I am happy with my one way conversation, and resigned to being in the dark about DFS channels, So hopefully NETGEAR will eventually get their act together about DFS!
Roger
roger_h
Jun 11, 2021Aspirant
