Carri1221
Jun 14, 2023Follower
5g internet won’t connect
My 5g won’t connect, everything shows online however when trying to connect to a console it shows a message that it cannot connect to the router. When I called tech support the claimed that I needed t...
michaelkenward
Jun 18, 2023Guru - Experienced User
Carri1221 wrote:
When I called tech support the claimed that I needed to purchase firewall protection, but when then also tell me that I need to also purchase “support” in order for them to help me.
That wasn't Netgear that you talked to.
