Trottirj's avatar
Feb 23, 2020
5g keeps dropping out
I have the same issue. 2.4g is always okay. 5g keeps dropping out.  I tried different channels but still the same problem.  Coincidentally I just added a google nest mini to my older google home an...
  • Trottirj's avatar
    Trottirj
    Feb 26, 2020
    Thank you very much. I did as you suggested.
    That does seem to fix my problem. I have the 5g and the connections seem solid now for 24 hours.
    Thanks again.
