aeroflyer711
Sep 02, 2021Aspirant
5G Keeps dropping
Firmware 1.3.2.134 My 5G wifi keeps dropping out randomly than fires back up automatically later. I've seen firmware issues identified but I didn't see anything specifically for the R6900P. Any...
Sep 02, 2021Guru - Experienced User
I wouldn't upload via wifi. when we see issues with corrupt firmware it tends to be by those who did it over wifi or using the app.
aeroflyer711
Then can you please briefly explain the process you suggest?
- plemansSep 02, 2021Guru - Experienced User
just follow the manual firmware upgrade process but use the older firmware. I just recommend doing it over and ethernet connection and not via wifi.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- aeroflyer711Sep 02, 2021Aspirant
I'll have to bring my laptop home over the weekend to upgrade over LAN but I did update over WIFI today and had the issue. It does say "connected without internet" on my phone.
- michaelkenwardSep 03, 2021Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Check the section in the manual on updating the firmware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads. So you might find it helpful to stash away a copy of the manual.- aeroflyer711Sep 03, 2021AspirantThe manual also only mentions updates via WiFi and the person helping me has mentioned not doing wifi which is why I wanted to clarify the exact process they were proposing to make sure I wasn't doing things different than they suggested. Also, I can reset the router by just pushing and releasing the reset button or I've seen the hold the button, unplug, hold the button, ... Option (I forget the exact sequence of the top of my head).
- plemansSep 03, 2021Guru - Experienced User
aeroflyer711 wrote:
The manual also only mentions updates via WiFi and the person helping me has mentioned not doing wifi which is why I wanted to clarify the exact process they were proposing to make sure I wasn't doing things different than they suggested.----The only difference from the manual is hardwiring it in and using the older firmware. Also, I can reset the router by just pushing and releasing the reset button----yes. After the firmware is fully installed and the router reboots, push and hold reset for 7-15 seconds. or I've seen the hold the button, unplug, hold the button, ... Option (I forget the exact sequence of the top of my head).
