GSSR71
Feb 04, 2021Tutor
5g Not working
This morning the 5G band just quit tranmitting. The router still exhibits the 5G bulb lit but no signal anywere in the house. It's even flasshing. Using the router admin, it indicates it is active...
GSSR71
Feb 07, 2021Tutor
The factory reset corrected the problem. The 5G band is now putting out a signal. Thank you for your help. I really don't know what caused the issue. The firmeware version is still the same. I've disabled the auto feature. If that was the problem, at least I can manage it.
Feb 08, 2021Guru - Experienced User
Glad it worked!
