datyperry96
May 18, 2022Follower
5g wifi but no internet
I have a tri-band R8300 router. Out of nowhere my 5g will connect to the wifi but no internet. I have tried rebooting the router. Unplugging and plugging it in after ten minutes. I went on my phone fo...
michaelkenward
May 19, 2022Guru - Experienced User
You get some sort of error message on some device or other?
The only thing that is red on my router is the 3 slot.
Which one is that? The only LEDs on the front that do "red" (amber) are power and Internet. If either of those is amber, you have a problem. A dead router or no Internet.
What about the 5 GHz wifi LED?
Tried pressing the wifi LED button?
