Bob-ruth
Mar 30, 2021Aspirant
5g works on one computer but two others can't see it
Bob-ruth
An addition - new to this, so don't know what I'm doing. All three of these conputers are running windows 10. The two that won't find the 5g are Dell laptops and the one that works on the 5g is Windows surface book 2.
- plemansMar 30, 2021Guru - Experienced User
What wireless chip is in the 2 that it doesn't see it?
Are they dual band chips?
What driver is installed on them?
what router do you have?
- Bob-ruthMar 30, 2021Aspirant
Way too many questions for non computer literate. Don't know answers. Both Dell laptops bought used and they work fine on wi fi router but will not show me the 5G option in available networks, The 5G seems to work much faster on my Windows surface. But it is solid state drive where the two dells are mechanical hard drives. The windows runs windows 10 pro, the dells are standard windows 10 as loaded by dell. Just thought there might be some generic answer to why they would not offer the 5G. Also, our i-phones show and use the 5G connection. I'll just get by without the 5G on the dells. Thanks for trying he help a computer illiterate.
- KitsapMar 30, 2021Master
Are you sure your used Dell Laptops have the capability of connecting to the 5 GHz Wi-Fi band? They may be older models without that capability. Have they connected to a 5 GHz band on some other router?
You can go to the Dell support web site and put in the machine service tag numbers and check to see what Wi-Fi radios were in the machine when it left the factory.
