Hikari1489's avatar
Hikari1489
5Ghz-2 not appearing (AC3200 Nighthawk X6 R8000)
Hello,   My router has been working with no problems. Updated and used both the nighthawk app and tried the web genie. I cannot get my 2nd 5g signal to appear on any of my devices. The 2g and 5g-1 ...
  • plemans's avatar
    Aug 10, 2019
    the japan thing does impact. Do you have the region setup for Japan on your router? And the device you're using?
    japan has different wifi channels that can't be broadcast on or can be broadcast on.  this is the list. (from wikipedia)
    https://en.wikipedia.org/wiki/List_of_WLAN_channels
