Hikari1489
Aug 10, 2019Aspirant
5Ghz-2 not appearing (AC3200 Nighthawk X6 R8000)
Hello, My router has been working with no problems. Updated and used both the nighthawk app and tried the web genie. I cannot get my 2nd 5g signal to appear on any of my devices. The 2g and 5g-1 ...
- Aug 10, 2019
the japan thing does impact. Do you have the region setup for Japan on your router? And the device you're using?
japan has different wifi channels that can't be broadcast on or can be broadcast on. this is the list. (from wikipedia)
Hikari1489
Sorry, should of stated that this is a new router i got recently. About 2 weeks ago. When it was installed it was updated though the web browser. I wouldn't know if it worked before an update or not. When I first started using it the 2nd 5g signal was never appearing on my devices, yet it shows that it is active on the router itself and on the app and web browser.
Do you think it would be worth trying downgrading to a previous firmware to fix? If so which firmware should I downgrade to?
Aug 10, 2019Guru - Experienced User
Which version are you on?
