tumbleweed22's avatar
tumbleweed22
5Ghz-2 not appearing (Nighthawk R6700v3)
A year ago, I was able to tap into both WIFI channels - 2.4GHz and 5GHz.  I realized in the past 3 months that I am not seeing my 5GHz channel. When diving into the router admin setup, it appears th...
  • plemans's avatar
    May 22, 2021
    5ghz doesn't broadcast on the 1-11 channels.
    Theres a reason those channels are avaiable.
    List of WLAN channels - Wikipedia
    what device are you scanning with?  Does it have 5ghz? not all devices do
