Andypandy88
Sep 17, 2023Aspirant
5Ghz channel 116 no longer works
Nighthawk(R) X4S R7800 Hardware Version R7800 Firmware Version V1.0.2.92 GUI Language Version V1.0.0.439 Operation Mode AP Region Europe Mode Up to 1733 Mbps Hi guys. Today I set my Nighthawk to 5GHz ...
Sep 17, 2023Guru - Experienced User
Do other channels work?
Andypandy88
Yep. Channels 36-104 seem fine. Only got a little crowded where I live.
- schumakuSep 18, 2023Guru - Experienced User
96-140 should be workable under European legislation, not all up to combined 80 MHz (or 160 MHz) under DFS/TPC limitations.
Worth noting 120-128 are forbidden in Australia and Canadian regulations (so there is no 80MHz total bandwidth available with the base channel 116). Probably some of these limits were accidentally applied to the European config?
