DWAL
Sep 28, 2021Aspirant
5GHZ channels not available anymore
Hello,
Since the last firmware update V1.0.4.76 I can't connect anymore to none of the 5GHZ channels anymore. I can see them with the Netgear genie app on my PC but I'm not able anymore to change the settings. I also notice that all channels have not the same SSID name, bot none I'm anle to change.
Can anyone help me to solve this issue?
Regards DWAL
1 Reply
Whenever I run into an issue after a firmware update, I recommend a factory reset and reinstall. (don't use a backup configuration).
If that doesn't help, then I'd recommend downgrading the firmware a version.
