Curatenshi
Jul 19, 2021Follower
5GHz Network isn't showing (Model R700) - In Advanced it shows a red X not a green Check
I'm trying to get my router's 5GHz channel to show and be available (it isn't showing for any device currently). The light on the physical router for the 5GHz is on like the other channel. It says ...
wcalifas
Jul 19, 2021Prodigy
You can try resetting your router or reloading firmware on it and see if that fixes it.
