maskasuba
Nov 17, 2023Follower
5ghz network no longer appearing as an option to connect to
5ghz Wi-Fi network no longer appearing in my networks I have a netgear nighthawk R6700v3 and my 5g network just disappeared one day and I have no idea how to get it back. I’ve tried calling the ne...
michaelkenward
Nov 17, 2023Guru - Experienced User
What tells you that the router is not broadcasting?
Is the 5 GHz LED on?
Have you ruled out the possibility that they wifi clients just can't see it?
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
