ooVisi
Oct 03, 2021Aspirant
5GHZ Not Showing on R7800
I noticed that my 5GHZ network wasn’t showing and did a lot of things to try to get it working again to no avail. I rebooted it, I factory reset it, I tried changing the channel. I checked to make sur...
Oct 04, 2021Guru - Experienced User
Have you tried disabling smart connect?
How do you know 5ghz isn't working?
- ooVisiOct 04, 2021AspirantSmart connect is off, I checked on multiple devices and 5GHZ doesn’t show up. On the nighthawk mobile app when I manage devices and hit the filter button, it only has 2.4 ghz and wired as an option to be filtered but not 5 ghz
- microchip8Oct 04, 2021Master
Go to http://routerlogin.net or http://192.168.1.1 with a browser and see if 5 GHz is enabled. The app is mostly useless.
- ooVisiOct 04, 2021AspirantIt is on, it shows that it should be working, I’ll probably just have to get a new one unfortunately.
