-tine-
Oct 21, 2015Aspirant
5ghz very slow with R7000 router
Hi, I am using the R7000 router at my home for some time now. Since the beginning the speed on the 5ghz band was very slow. First I thougt it might be a problem of my Iphone, but now I have to se...
- Oct 21, 2015
Others have had issues with the 5Ghz channels with the version of firmware you have, they seem to have luck actually going back to the previous version, 1.0.4.28. You can get it here downloadcenter.netgear.com/en/product/R7000
There is a beta firmware available, you can find the info here https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-firmware-v1-0-5-44-limited-release/m-p/991888#U991888
Babylon5
Oct 21, 2015NETGEAR Employee Retired
What is the range of these devices from the router? Do they have clear line of sight?
What kind of ISP service do you have, what is the brand and model number of your modem please?
- mondenathOct 21, 2015Prodigy
Ok did you try the below firmware . though it has nothing to do with your current firmware.
Also ignore iphone for now and see if you have 5ghz n or ac client and see the link rate for actual throughput as well signal strength.
In Iphone post a snapshot on 2.4ghz signal DB and 5ghz DB using the netgear analytics software. Also the graph which tell how many signal interferance in that area.
- -tine-Oct 21, 2015Aspirant
Hi,
I did not try the firmware you mentioned, I am currently using V1.0.4.30_1.1.67 (no new one availabe, at least thats what the webinterface tells me).
I do not find a netgear analytics software on the app store, do you mean the netgear Genie ?
Signal strength of my 2.4ghz network (using inSSID) is -43, for the 5ghz -45 and -89 on the two displayes channels. The link rate for the 2.ghz network is 144Mbit, for the 5ghz 300-360Mbit.
I just did a speed test on an internet website, I get 32Mbit downstream using 2.4gz and 2.7Mbit using the 5gz one ...
Christine
- rpoffenOct 21, 2015Virtuoso
Hi,
I am using the devices in the same room with a clear line of sight of perhaps 5-8 meters. My ISP is a cable line (Vodafone Germany) with 32Mbit downstream, nevertheless I do not have any speed limitations when using the 2.4ghz signal.
I am using a netgear nighthawk R7000 router.
Christine
