-tine-
Oct 21, 2015Aspirant
5ghz very slow with R7000 router
Hi, I am using the R7000 router at my home for some time now. Since the beginning the speed on the 5ghz band was very slow. First I thougt it might be a problem of my Iphone, but now I have to se...
- Oct 21, 2015
Others have had issues with the 5Ghz channels with the version of firmware you have, they seem to have luck actually going back to the previous version, 1.0.4.28. You can get it here downloadcenter.netgear.com/en/product/R7000
There is a beta firmware available, you can find the info here https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-firmware-v1-0-5-44-limited-release/m-p/991888#U991888
-tine-
Hi,
I am using the devices in the same room with a clear line of sight of perhaps 5-8 meters. My ISP is a cable line (Vodafone Germany) with 32Mbit downstream, nevertheless I do not have any speed limitations when using the 2.4ghz signal.
I am using a netgear nighthawk R7000 router.
Christine
Babylon5
Oct 21, 2015NETGEAR Employee Retired
Thanks for the info. If you have a modem, can you tell me the brand and model number please?
