Dancolt1234
Apr 19, 2021Follower
63A7OC7XA5313 mesh nighthawk
Hi I bought this hooked it all up and it says I can't connect to internet . Is this because my home router is still hooked up? I see my original router and the nighthawk. When I click on nighthawk it...
Apr 19, 2021Guru - Experienced User
What system did you actual buy? A model number helps.
Cascading routers isn't a recipe for a working network. It causes a double nat.
What is Double NAT? | Answer | NETGEAR Support
how do you actually have your network laid out?
