donovanpl123's avatar
donovanpl123
6700v2 WiFi-Wi-Fi Router
I’m currently using a Xfinity hotspot on a long term basis.  I am concerned being exposed to being hacked.     1. Would Xfinity have a problem with me implementing a router with multiple devices be...
  • plemans's avatar
    Feb 02, 2025
    You're going to want something that supports wisp mode. The R6700 doesn't.
    You'll want to look at a travel router. GL-iNet makes pretty solid routers that some have support for wisp mode.
