VonSwain
Oct 22, 2022Aspirant
6700v2 WPS won't allow me to change network key
I have had the R6400v2 for several years now. No issues at all. Yesterday either a power surge or something happened where the router and internet were knocked offline for an hour. When I returne...
Oct 22, 2022Guru - Experienced User
What modem/gateway is the router connected to?
What firmware version is on it?
- VonSwainOct 22, 2022Aspirant
Firmware Version
V1.0.4.128_10.0.104Modem/Gateway
Default
- plemansOct 22, 2022Guru - Experienced User
Modem/gateway--Default?
That tells me nothing. What actual modem/gateway is it? look on the label
Oh, I thought you wanted the gateway. It is Netgear CM500
- michaelkenwardOct 22, 2022Guru - Experienced User
VonSwain wrote:
Modem/Gateway
Default
That does not answer the question.
What is the make and model of the box that sits between your router and the Internet?
