VonSwain
Oct 22, 2022Aspirant
6700v2 WPS won't allow me to change network key
I have had the R6400v2 for several years now. No issues at all. Yesterday either a power surge or something happened where the router and internet were knocked offline for an hour. When I returne...
michaelkenward
Oct 22, 2022Guru - Experienced User
VonSwain wrote:
Started applying the settings that I had and this message popped up "WPS process is in progress, please apply the changes later."
How were you applying those settings?
Manually or from a backup that you had saved?
Where did that message pop up?
Did you try using WPS to set up something? It doesn't usually kick in uninvited.
Thinking that it was still installing some firmware update, I let it set overnight.
You already have the latest firmware, so it should not need to update itself. There can be times when firmware is damaged but not beyond use. In those cases, you could try manually updating the firmware again, just to rule that out.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
